HangOutdoors
- Royal Oak, MI
View attachment 132907View attachment 132908View attachment 132909View attachment 132910
[/QUOTE
question about the jack stand, any particular reason? and is that XO actually off the ground in the pic? just wondering if there was an advantage to it or something. thanks
My ARK 750 arrived today. What a beast this thing is. I could barely lift it out of the box. Hopefully since I moved my winch back 3 inches it will fit. Good Lord this thing is HUGE. This should work great on my sloped driveway. I like how you can lock the wheels too. I bought some tri-groove nuts to help deter any thieves. The mods keep on coming.Had to move winch forward to fit View attachment 132935
You could get something like thisIs there any dis-advantage to going with a flat bottom instead of wheels? I have yet to have an instance where I needed the front wheel. The wheel scares me since it can move the front of the trailer.
If it were me, I would put one of these on each side as supplements. No way I'm trusting that 5000 lb. rating.I've been thinking of something like this, if I do replace it, though I do need something with an extended lift.
Bulldog Trailer Jack Tubular Swivel, 5000 lb 178201 | Zoro
Order Bulldog Trailer Jack Tubular Swivel, 5000 lb, 178201 at Zoro.com. Great prices & free shipping on orders over $50 when you sign in or sign up for an account.www.zoro.com
It doesn't look any more robust that the 1000 lb Dutton-Lainson I'm replacing. I'm sure it may be sturdy, but what about when it's extended? I have no first hand knowledge other than looking at the picture.What makes you distrust it?
There is no lock, me I place a thin 1" paver on each side of the wheels, raise it up just enough to lighten the pressure on the wheels and use a jack stand to support most of the weight like @HangOutdoors doesWait how do you lock the wheels?
What size wrench do you need to loosen the two nuts that secure the OEM jack? Would it help to shave the thickness of the wrench down a bit with a bench grinder?
