havewill22
 - Kapolei, Hawaii
I have a 2006 AR230. I just put new motors in on port and starboard side. I'm having the same issues on both sides, it would start and idle and run on both sides while on land with the hose running but when I'm at the docks and it's in the water, it has a hard time starting. If it starts, it'll idle but as soon as I give it throttle and back to neutral, it'll die and have a hard time starting again.
I have YDS and have no codes, I've set the TPS to be within value (no wake mode button works).
One ECU is brand new, and the other was rebuilt from regulator rectifier.
I've replaced both fuel pumps. Oil level seems good.
I bought the boat in 2023, my thinking is that while it's in the water, there could be load on the jet drive unit and there hasn't been any maintenance done, maybe I need to grease the or replace the cone bearings? Since 2023 til now, I took the boat out twice before both engines failed. Just finally got to putting new motors in.
While the boat is on the water at the dock and I get the engine running, I can leave the docks and it'll run while above idle speeds, it'll also get up in rpms no problem, but once I get it back to neutral, it'll die and have a hard time starting. If it's running on land and I blip the throttle, it'll still stay running, not when the same is done on the water.
If anyone has any suggestions, I would really appreciate it, I did read through the forum and found someone with a similar issue on one enegine. One person commented saying that the engine might not be running on all cylinders. I'll check my compression as the next step but it sounds like it is running on all 4.
Thank you
Thank you
