Russian outboard jet drive - Impulse
satovod
Turkey/Russia/Spain
90/115/135hp, 210kg
$5000 brand new.
How many horse power?
three versions 90, 115 and 135 horsepower based on same engine block
That is interesting! Never seen or heard of an outboard jet.
Looks like I need to pay more attention to what is happening in the boating world!
Yep. I see many jet outboards here. They are used on the shallow Sacramento river on fishing boats.
You need look no further than Mother Yamaha for a jet outboard.... A buddy of mine runs a few river boats up in Talkeetna and Ketchikan AK..... They run great!
F150 Specifications
Engine TypeIn-Line 4 Cylinder
Displacement2670cc (163 c.i.)
Bore x Stroke94.0 mm x 96.2 mm (3.70 x 3.79 in)
Prop Shaft Horsepower105hp @ 5500rpm
Compression Ratio9.0:1
Fuel/Induction SystemMulti-Point EFI, 16-Valve Double Overhead Camshaft
ExhaustThrough Jet Pump
IntakeFour Individual Throttle Valves
Ignition SystemTCI Micro Computer
Spark PlugLFR5A-11-00-000
Alternator Output35 Amps (1500 rpm to W.O.T.)
Starting SystemElectric
LubricationWet Sump
Engine Oil Capacity4.5L/4.L w/without filter
Full Throttle RPM Range5000-6000 rpm
CoolingWater/Thermostatic Control
Recommended Engine OilYamalube® 4-M (See Owner's Manual)
Recommended FuelRegular Unleaded (Minimum Pump Octane 87)
Recommended Fuel FiltrationYamaha 10 Micron Fuel/Water Separating Filter (external)
Ethanol Blend Limit10% Maximum
Gear RatioDirect Drive
Gear ShiftForward, Neutral, Reverse
Shaft LengthFits 25" transoms
Degree of Tilt70°
Degree of Trim-4 through 16°
C.A.R.B. Rating3-Star
Dry Weight225kg (495 lbs) w/jet pump assembly
Steering Angle (maximum)35° from center, either direction
Warranty3-Year Pleasure (2-year on jet pump assembly), 3-Year Government (2-year on jet pump assembly), 1-Year Commercial (1-year on jet pump assembly)
Spec Weight1
In Alaska rivers they have been running outboard jets for years.
F150 Specifications
LubricationWet Sump
Degree of Tilt70°
Spec Weight1
Don't "Bore & Stroke" me....how fast does the damn thing go? That's what we want to know dammit!
I'll bet it's a blast on a flat bottom boat!
On a related subject @satvod, didnt you use one of the outboard jets to power your homemade jet pack / jet lev? Please tell us more about that. I recall seeing only one or two pic on yjb (one of you in flight) without much follow up.
@satovod ;)
