Speedometer
Terrance
Porters Lake Nova Scotia Canada
Glastron
GT
Hello Glastron jet boat owners. I have a 2015 Glastron Gt187 and the first run was today. Everything is good after a winter sitting. However I did notice the speedometer was not working. The digital speedometer was working in the other side of the instrument cluster. Any tips or instructions would be appreciated.
Thanks
genwrx
Houston, Tx
Glastron
GTS
Try turning the main switch off, and or disconnect battery, if it's GPS, it may need a good power cycle, other than that check the wiring behind cluster, make sure it is not loose.
Terrance
Glastron
GT
Hi Genwrx. Thanks for the reply. The main connecting clip is plugged in well and the fuel gage and volt meter are working correctly. It’s just the speedo needle not moving for some reason. I will take the GT187 out for a longer run tomorrow and see if the speedo “wakes up”. Happy Boating.
Kyle Mekulik
Newburgh New York
Glastron
GTS
You need to unplug the gps module under the dash and then plug it back in and it’ll work I’ll try to upload a phone of wha,t it looks like
Jeff85
Nd
Glastron
GTS
Late to reply, but I have to unplug that sometimes when I haul my boat to different lakes . Works though .
NavyShooter
Windsor Junction, NS
Glastron
GT
Well, this is amusing. I have exactly the same problem with my GT187 this evening....it's also my first night with the boat in the water this season.
I'll go digging under the dash tomorrow. Sun's down and the 'skeeters are insane out there tonight.
Thanks guys!
NavyShooter
Glastron
GT
And mine is working this evening....I"m guessing the GPS hadn't had time to update its almanac in the short time that the boat yesterday, and by the time today rolled around, it had done so.
NavyShooter
Glastron
GT
Terrence - question for you - what kind of top speed are you seeing out of your GT187?
Mine seems to top out at about 7550 rpm, and 32 MPH.
Is that what yours hits?
Brad
Jeff85
Nd
Glastron
GTS
Hi Brad.
Im about the same. Pending the number of passengers. 35 is tops.
I have the supercharged engine and see low 40's. 45 was about the fastest with an empty boat. How many hours do you have? Almost sounds like the ECU is in it's break it period still.
Noel Cain
Glastron
GTS
I have the 250hp and am running 42mph with three people on board, 45mph so far with just me on board. Im only 10hrs on the boat, so not sure if shes gonna open up any more than this.
