B0at1n
- Little elm
Help, stuck on the water, no water peeing and strainer grate seems to be clear.
If you want to call my cell is 682-551-7669 names Robert.Help, stuck on the water, no water peeing and strainer grate seems to be clear.
[USERGROUP=9]@HELP[/USERGROUP]Help, stuck on the water, no water peeing and strainer grate seems to be clear.
It looks like it’s on in pictures but it’s notBuddy is towing me now, I unhooked this line which I assumed was the water intake, no water is coming out though. So I’m guessing the clog is prior to that. View attachment 93522
check the oil for water. If the oil is thin and way up on the stick you've got water. You can run the engine for 15 seconds, then check the oil. If miley you have water.
