utahrd
- holladay, utah
- SX
Okay Guys (and Gals),
I will be putting my boat into a relatively isolated part of the Pacific Ocean this summer, and want you all to double-check my thinking on the preparation. This is really about the trailer...as it is the biggest identifiable issue. I have a beautiful painted trailer. I know dipping it in salt water is not the best idea...but after EXTENSIVE research on the topic I have decided it is probably my best option with appropriate preparation.
Of course, if anybody would like to swap out their galvanized trailer for my painted one + some cash, let me know. I live in Salt Lake City. Barring that option, here is what I have considered:
Abandoned Idea: Buying a new Aluminum or galvanized trailer: don't want to spend $3500 right now
Abandoned Idea: Boat lift-- my destination has no boat lift within 40 miles of where I am boating. Plus, weather, and conditions and unfamiliarity with the coastline make the 40 mile journey seem unsafe. also not cheap $400 for lifts plus gas cost
Abandoned Idea: rental trailers. I have identified rental trailer companies, but cost of renting will end up $1500 for my long duration trip. No option to rent for only the days I need to launch and retrieve at my destination because no rental companies within $300 each way gas cost.
Abandoned Idea: galvanizing my painted trailer. I gave this one a lot of thought. I could dissassemble my trailer, get it sandblasted, and take it to a galvanizer. The galvanizing would cost ~$400, the sandblasting between $150-$300 depending on if I do it myself or not. This would be an interesting solution, but I have no timely or inexpensive way to remove the boat from the trailer and transport and load a trailer frame to a galvanzier, and the time to dissassemble and reassemble a trailer makes this option more of a "too much of a pain" than cost issue. If you live in or near salt lake and are willing to do this work at a fairly reasonable price, let me know.
PREFACE to the planned idea: I know that nothing I do will keep corrosion from setting in on the painted trailer. If I can get 4-5 years out of my trailer, I will be happy.
PLANNED IDEA:
So there you have it. What do you all think of this idea. My trailer is in excellent shape now. With this system, can I expect 4-5 years with this trailer?
PLANNED IDEA:
- Professional bearing re-pack
- ensure all exterior paint is in good condition, and use rustoleum to touch up existing nicks.
- spray "fluid Film" (http://www.fluid-film.com/) with my pressure sprayer inside all tubular steel of the frame. (i have identified a spray wand attachment that will let me extend about 30 inches into the steel cavities. Also spray entirety of exterior.
- Fabricate some type of intenal plug at the open ends of all open tubular steel.
- Use Black 3m 4200 to seal all internal plugs, as well as holes where wires and lights exit the trailer frame, as well as around all welds. Goal is to seal the tubular steel so no water reaches within
- Spray a ton of fluid film on all axles, hubs, etc.
- Only launch boat when bearings are not hot, so as not to draw saltwater into hubs/bearings
- after launching, wash trailer off completely with tons of freshwater, or go to carwash with trailer and rinse. Salt-Away or similar product also a consideration at the wash step (will salt-a-way interfere with fluid-film coating?)
