Boat Stuff Twin Engine TVW set - $400
Rumbo
Arizona
Selling my Thrust Vector Wakes. Upgraded to the Wake Wedge as it better suited our needs. Everything is included except epoxy and thread lock, both of which you can purchase at any hardware store or Walmart. Two of the bolts that mount the fins and bucket to the nozzle are damaged (I have and will send the bolts but they were damaged from using them to remove the upstop brackets from my nozzles). All other bolts, nuts, washers, sleeves, springs, brackets, etc are there. The anodized finish has washed off. Never been in saltwater. Includes standard ground shipping to the continental US. JBP has an install video on YouTube and they’re simple to install. Everything is in like new condition except the finish. The low speed steering control is fantastic with these on!
Still have this?
Yes I do.
Sorry for the delayed response, I’ve been way too busy with work the past two weeks.
Are the for boats with articulating keel? Will they work on 2006 AR210?
Are you flexible in the price?
Yes. I had them on my 2018 AR240 without issue.
I will consider a reasonable offer
I don’t think that will work on my 2006 AR210 as I do not have the Articulating Keel.
Do you have the model number of the one you are selling?
I can’t find the model number. The articulating keel won’t be an issue as the only difference is that the starboard side inner fin has a notch for the rod that connects the nozzle to the articulating keel. This doesn’t impact functionality at all. I think the only thing to determine is if the nozzles are the same. I will try to see if I can contact JBP to see what the model number is and comparability is for what I have.
JBP did respond and says they will fit.
Price drop...$250 obo
Still available? Will these fit on a 2016 ar240?
They are still available. I believe they will fit a 2016 but you may want to confirm. Mine is a 2018 AR240.
