Underwater Swim Lights
Colin MacEachern
AR192
Has anybody installed underwater swim lights on their 190/192/195? I am thinking about getting the Aqua-Bright II Blue from West Marine (https://www.westmarine.com/buy/west...underwater-light-2-pack--14996219?recordNum=9) but am unsure how to wire them and how to install them properly to ensure I wont have any problems. Has anyone seen or can anyone provide a write-up on installing and wiring underwater lights? I do HVAC so I can read schematics all day, just need a good place to start.
I'm interested too...
My only concern is there is no specs for this? What kind of led iodes are they using in them? Just make sure it's bright enough for your needs before you pull the trigger. Below is sneak peak of what i have on my AR. Full write up will be coming in next few weeks when I'm done.
niiiice - looking forward to your feedback!
Just curious how are you reaching the bottom corner? R you removing the walls in the motor compartment?
Are you referring to the bottom corner of the hull? If so that is access to it in the engine compartment. You would just have to seal around it.
yea I think with the older ones we have to remove the engine compartment walls. I haven't seen the inside of the newer models but I would imagine from your description they are different.
I spent about $175 for the diablo royal boatlpug lights
easy install and they come in white, red, green or blue. the ones I have are two 1000 Lumen lights....they also have 8000 lumen ones that are more expensive and I would imagine would be insane! Kind of wish I got those...
Very nice. They seem to have high output in the water.
