Jasonsbiz74
- CLE, OHIO
- Limited S
Love that white sport grille ! Cant wait to get my project rolling
Sounds fun. May be easier to run all new wires. I plan on disconnecting factory tweeters too. They are annoying.The current wiring for the '15 242 is not not straight up, I cant remember how now ...there is a thread some place that explains how they are wired...I would try track it down. I plan on rewiring all the wires but I guess I should track it down too
@MattFX4 - Lots of diiferent ways to do this and many have posted what they did. Personally with the components are installing I would run new high quality wire to everything. 12 gauge to the sub and 14 gauge to everything else. I am in the middle of adding speakers, amps, and rewiring as well.Last 4 speakers delivered today. Been thinking about this upgrade, and my head is hurting. I hope I am not biting off more than I can chew here. I have installed car audio systems before, so have general knowledge. I am concerned with how the boat speakers are currently wired. Since I will be running an 8 channel amp, all 8 speakers with have their own channel. I am not sure if the current 242 speakers are wired this way. Also the thought of cutting holes in fiberglass for new speakers scares me. I also have to find a way to mount the amps...
@Mainah Any thoughts of where you are going to mount your amp board? I ordered 12 and 14 awg wiring today, so I think that's the last piece before I get started.@MattFX4 - Lots of diiferent ways to do this and many have posted what they did. Personally with the components are installing I would run new high quality wire to everything. 12 gauge to the sub and 14 gauge to everything else. I am in the middle of adding speakers, amps, and rewiring as well.
Here is what I did to cut the fiberglass and mount the speakers. Safety note: respirator (not a dust mask), googles, ear plugs, gloves, and a disposable paint suit are highly recommend by me when cutting molded fiberglass.
First I cut out 2" increased diameter 3/4" thick hdpe backing rings with a jigsaw on a circle jig that I made and pilot drilled the mounting holes. I cleaned up the inside edges with a detail sander. I then used the rings to template the front side of my masked mounting location, drilled two coutersunk holes for each backing ring for indexed set screws, drilled the speaker mounting holes in the fiberglass, and then mounted the rings to the backside using the indexed set screws from the front. FYI On my 2016 I just gave the top trim rings on the cup holders a turn and they will come right off to reveal three top mounted screws for easy removal of the cup holders so that you can see and get to what you are doing easier.
Note that the only holes in the fiberglass so far are the drill holes and the rings are now mounted behind. Next I drilled a hole to get a trim router bit started and used a trim router to cut the fiberglass which followed the rings nicely. Made a huge mess but i got perfect cutouts with no chipping and the backing rings are already in place and pilot drilled in line with the hull. I am going to apply a thin coat of epoxy with a brush to the exposed fiberglass edges. Perhaps this method is overkill but I like to only do things once and the backing rings will not only provide secure mounting but also reduce fiberglass deflection when the speakers are osciallting which will somewhat improve audio quality and amplitude. One other added benefit was that the backing rings ensured as a final check that I would not cut through anything that I did not intend to like the main wiring harness running down the starboard side or the throttle cables.
My amp board is in progress as well. I have used 3/4" HDPE for this as well and did a 1/4" round over on the edge to avoid sharp corners. I will do a full post once complete. Already taking longer than I expected :-( but no bandaids needed for me or the boat yet either
Good luck.
@MattFX4 - I am mounting mine over the helm opening behind the factory controls at the top of the opening. I left 6 inches at the bottom to access the diagnostic connections and to run all the wire from behind the board through chamfered holes for each wire for built in wire management and a clean install. Your amps may be too big for this location. In which case others have mounted the board to the opposite side of the helm compartment behind the starboard bow seat back. I used a fish tape to get the port bow speaker wire pulled around the anchor locker and zip tied to the existing harness that is there. For power and port speakers to the stern of the day head I ran the wires next to the the shift/throttle cables under the fuel tank access floor panel as there is a channel that that feeds under the helm. I zip tied to the factory harness at all points to keep the wires wrangled. I ran over 100 feet of wire in total and that does not include the tower or the swim deck. Hopefully I can start connecting it all up at the board on Saturday and finally hearing it will aleave the cramping from being in that helm area for an extended period. I will post photos once complete. My best tips for running the new wires are gloves, full length shirt, and pain killer for being contorted (ibuprofen, beer, whiskey).@Mainah Any thoughts of where you are going to mount your amp board? I ordered 12 and 14 awg wiring today, so I think that's the last piece before I get started.
You did not specify where beer would be in the process?lol ok. I'm sure beer will be part of the installation process when I get started. Post plenty of pics when done. I ordered 100' of 14 awg speaker wire, but that may not be enough. Think I order around 12' of 12 gauge for the sub. Hopefully that will be enough. I need to get my hands on a fish tape too. Thanks for the input!
