Had a few outings with the sound system - we’re very pleased with the results.
Hertz Speakers - they sound great. I had
some reservations before purchasing them as JL Audio / Wet Sounds seem to be the go-to for most, but after hearing them in action, I have zero criticism of them. They look good, sound great (the bass is impressive), and were a great value.
Adding the 3rd pair in the cockpit is absolutely worth it and should be at the top of anyone’s list for upgrading audio in the 19ft boats.
Infinity / Kicker Amplifiers - No complaints. They seem to be a great match for the speakers / sub.
Wet Sounds Soundbar - Overall we’re pretty satisfied with soundbar …
Combined with the subwoofer, the sound behind the boat is excellent. The bar itself gets plenty loud and the overall sound quality is good. It definitely meets our goals for a low visual and spacial impact - no one’s hit their head on it and it doesn’t impair our ability to operate the boat with the tower down (going under low bridges).
One thing I noticed is that the tweeters have a
very narrow soundstage. As you get 10º - 15º off center from soundbar, you can hear a very noticeable fall-off in the higher frequencies.
It’s a good product, but there is room for improvement. I think some more purpose built racetrack drivers, passive radiators, and some revised tweeter grills would give the bar a fuller sound and wider soundstage in the same overall size. JBL has some offerings that probably accomplish all of that …
Kicker TB 8” 4-Ohm Loaded Enclosure - Sounds great, but …
I wired my system for two subs (one in the starboard rear storage compartment, one in the port helm storage compartment). I’m content with the current sound, but I wouldn’t say no to just a touch more base when the soundbar is powered up and we’re 20 feet off the back of the boat. I
might add the second sub; we’ll see.
If I were to stick with a single sub, I might have purchased the 10” 2 Ohm Kicker TB subwoofer. More power/sound in nearly the same amount of space. The only problem with more sound in that space is the rattles. The cup holder insert on the starboard side rattled A LOT at relatively low volumes, even with the subwoofer off. I ended up epoxying strips of StarBoard to the back of it and lined it with
Kilmat. That fixed that particular rattle, but there are more rattle sources.
Not sure adding the second sub in the starboard helm is worth dealing with more sources of rattle …
