UnorthodoxCreations
- Hanover, PA
Trying to get my boat ready for the first time this season. Want to take it on vacation Thursday but it won't turn over. When I turn the key, neither engine will turn over. The corresponding tach lights around the edges as you turn the key but nothing. Dual battery setup and both batteries show 12.9v with no charger. I had them unhooked over the winter but I've checked my wiring a million times and it looks good. Everything else works, radio, blower, lights etc. Clean out port switches are pressed down. Throttles in neutral. Bypassed the lanyard switch with no change. Fuse on the wall coming off the battery selector switch is good. Seems like I've got to be missing something simple. Boat was fine when winterized. Fuses under the screw on cap of each ECU box look good.
I've replaced the interior but that shouldn't have messed with anything. New speakers and head unit in factory locations just yesterday and that all works fine. I remove the swim deck remote by unplugging it.
