2021 252S - both engines wont start - do not turn over
ezrider
252S
Hello all,
I brought the boat home today from winter storage, which is also temperature controlled, and I put the batteries in (which were on trickle and fully charged) and tried to start them.
I get this weird electrical, clicking type of noise. Similar to what happens when your car battery dies. Odd though that it is happening with both engines. Everything else works. The blower works, the screen comes on, the radio works, etc..
When I turn the key to try to start, something did come up on the screen, saying low voltage and contact your Yamaha dealer.
I ended up going to get new batteries. While I was at the store, I had them test the old ones and both came back good. However, for the sake of the process of elimination, I bought the batteries anyway, came home and installed them, and I'm getting the same exact problem. I do not think it is the batteries ...
Does anyone have any thoughts on what this could be? Perhaps something came loose on the ride home from being on the trailer?
Lanyard is in, the drives are in neutral ... Is there anything else that could prevent them from turning over?
Any thoughts? I would be super grateful. Thank you everyone.
the hatch for the cleanout port, check the cutoff switch. also make sure boat in neutral.
Just got mine out of storage…..same thing happened. Turns out I just forgot to attach the clip for the kill switch.
Make sure you hooked ALL of your battery cables back up. If you have checked the above suggestions, kinda sounds like a ground is off
I've had similar scenario and found my battery cables were not tight enough on the battery terminals.
This is exactly what it was!
I ended up looking at an old picture that I took from when I winterize the boat for the first time. I like to take a lot of pictures for reference and one of the pictures I took was of the battery cable set up.
One of the ground cables fell back and became hidden. So when I hooked everything back up, I didn’t see it. Quite the novice mistake. However, lesson learned …
On a similar note, there is another ground cable that lays on the bottom that has never been used. Not sure what it is for as the boat came new with it just being zip tied to other cables. I’ll take a picture for reference later and post it.
Thank you so much! As you can imagine, I am super relieved.
