Battery charging with BEP concerns.
TJP027
Wisconsin
212X
Need some help from the battery experts today. I posted on a Facebook group as well.
Last year, I installed a house battery—a 27 AGM Duracell. I didn't change the start battery from the 24 flooded that was in it. That is probably the first step to this.
The house battery seems to be not charging. The BEP light flickers on and off for the 2nd battery charging, but doesn't stay on.
My house battery was only reading 8v on Saturday.
Sounds like the little black wire from the DVSR is hooked up properly? Or perhaps the wire got broken? The DVSR could be going bad but I’ve not heard of that happening.
Doesn’t sound like you have an onboard charger? That is something you should have.
If your house battery was reading 8 volts it’s probably toast.
I'd start with simply swapping the house battery. If it's more than four years old it was probably due, and even if it wasn't, a full drain down to 8v probably did it in.
My boat has a little black wire that must be hooked to a battery ground. Yellow tag stating such.
Website sez my images are too large.
The black wire is connected to the Neg bus. I have taken the battery home to charge it.
Unfortunately, we are in a wet slip with no electricity
The dvsr closes at 13.2 and opens at 12.7, so I’m going to guess what was happening was that your start battery would get up to 13.2, the dvsr would close and as soon as it did the the voltage dropped below 12.7 because your house battery was so dead and would open then the voltage would go back up.
If your battery was at 8 volts it’s probably junk now. If it charges up take to an auto parts store and have it tested.
I have it on my Pro Mariner in my garage right now. The battery has gone through all the steps of the conditioner and says it is ready to go and charged.
When I go back out, I am going to check the start battery voltage. I have been monitoring the house and the start could be the problem.
Could you tell me the dimensions of your images? This should not happen and maybe something reverted during our recent upgrade @Bruce
above is a screen shot from my phone, thx.
@Bruce we are currently set to 2048x2048, did the upgrade change that, or did it perhaps disable our image resizer?
The attachment size limit had reverted to 2MB with the server upgrade. That is 24MB now.
