Bilge Pump Running while at anchor
gspersi
I just bought a 2022 Yamaha 210 FSH Sport. So far every time we are at anchor the bilge pump comes on about every thirty minutes and seems to pump at least a gallon if not two. I open the engine compartment and cannot see water actively flowing in from anywhere. Where could this much water be coming from?
Any through hull fitting. Next time your out pull the cleanout inspection cover and check for incoming leaks. It’s a very slow leak if it’s only coming on every 30 min so it may be hard to pinpoint. The other way is while it’s on the trailer is to put water in the bilge and see where it leaks out.
Congratulations 🎉🍾 on the purchase! You’ve bought a great boat and I think you will find it as enjoyable of a boat as I have!
So there’s a few areas where water can be coming in at on your boat. The good news is with some time and a little effort you can achieve a dry bilge.
First, carefully inspect the O ring on the drain plug, as @Babin Farms eluded to, having the boat on the trailer with plug in and add water to the bilge is a great to check for leaks. Pull the bilge pump automatic fuse which is next to the batteries before you start this process so you can add enough water to fully cover the bilge pump without it coming on to increase the head pressure inside the bilge. Spray the plug O ring with silicone spray as well as the female threads to keep things easy to install and remove.
Next, I’m going to assume you’ve had your live well full? If you keep the live well full the boat will list to port.
-If so there’s a couple of places where water can leak from the live well. There is an aerator on your live well, it picks up air from the little black circle with MAX AIR written on it, above the live well on the transom, there is a small black hose that runs from there down to a nipple on the aerator suction side fitting, that’s the one with the microfiche filter screen. I’ve seen a few 210 FSH owners finding the little black hose not connected to this little nipple, and when the live well is full a small but constant flow of water is draining into the bilge. You can pull the transom mounted cup holder on the starboard side and reach down in there to check that it’s connected.
-The next thing to check is the tightness of all the fittings on the live well. You’ll have to pull the clean out tray gain access to a couple of them although you’ll be able to reach the aerator fittings from the aforementioned cup holder. The others will require a certain level of boat yoga to get to from the clean out tray area. These are plastic fittings so just snug on them or you can strip the threads. While the clean out tray is off you can check the live well fill pump and it’s hoses as well as all the other clamps and such for tightness and corrosion.
-The aft bilge area also gives you access to the deck drain scupper and the live well drain scupper, when you’re on the water use a bright light and reach down there to check for leaks around the scuppers and the associated hoses. These scuppers are plastic from the factory and should be changed out with stainless steel fittings.
Check this thread I did on the OEM scupper replacement
Also
Once you’re done in the aft bilge spray this area down with silicone spray to prevent corrosion and it makes it look nice.
Next will be the anchor locker drain. Once our boats this drain is barely above the water line, if anyone is sitting up front it will be under water, and if the one on your boat is anything like mine it will be bringing water into the bilge. @drewkaree did a great thread on this and the link below picks up with my contributions to that thread. Be sure and get the little stopper to keep water out of the anchor locker once you’ve replaced the crappy OEM thru hull.
Other areas of water intrusion
Back to the clean out tray…. This needs to be sealed after it’s installed, don’t glue it down. You may find that the OEM screws are stripped so get some larger screws and put them in, just snug. I also eliminated the clean out tray drain as our boats have a channel on either side of the clean out tray, and that drain can allow water to shoot up into that area if you stop fast, I got the block off fittings from marine east, this eliminates another possible leak area and it makes it easier to get the clean out tray off and on. Next, you’ll want to get a mechanical hatch riser from Jet Boat Pilot.
Clean out plugs;
I’d also suggest putting clean out plug seal replacement kits on your plugs, then get a few sets of O rings from @Spooky pantz.
Check out this thread. This find by @TeeNGee deserves the Nobel peace prize! This will eliminate water coming up from the clean out plugs and onto the clean out tray, thereby eliminating this source of water into the bilge.
Cup holders; None of mine were sealed properly when they were installed! This is ESPECIALLY noticeable on the cup holders on the storage pods, when water gets on the top it just trickles down onto whatever is in there. All of the cup holders need to be sealed up. Also, the bow cup holders drain into the bilge, I just plugged mine. So do the transom mounted ones I ran drains from mine as well as the rod holders there to the additional deck drains I put in, if I was to do it over I’d just run them onto the deck.
Rod holders; The forward mounted ones have drains that go overboard but the aft ones drain into the storage compartments. Again, routed these into the additional deck drains but if I were to do it again I’d dump them onto the deck.
Once all these things are done you will have a dry bilge. On occasion I get a half a coffee cup full out of my bilge but that’s usually after I’ve used the raw water wash down extensively and I think it gets in through the removable seat back holes for the jump seats.
Check my signature links for other things I’ve done to my boat. One of the ones I like best is the addition of an electric pump for the raw water wash down and the additional deck drains
Thanks for all the advice. I have not used the live well but I don't know if the previous owner did. I did notice last week the boat listing to port though, but the live well itself is and has been dry as far as I know.
I keep the boat on a lift which is similar to having it out on a trailer (the difference being I have to wade into the river to unscrew the hull drain plug). So this morning I went over and got in the water and unscrewed the hull drain plug. At least a gallon of water came out so that was all below the level of the bilge pump.
But when I pulled the drain plug a large chunk of clear silicone popped out. It looked like it had a partial molded shape of a fitting as if it was half the silicone that used to be around a hose or thru-hull fitting. It was good sized like 1" by 1" by 3/8'. So likely there is some thru hull fitting somewhere that is missing half its silicone. I did spray silicone on the drain plug/o-ring and both male & female threads before replacing it.
I did not have anyone around to see if any water I poured into the compartment leaked anywhere so that will be next to try.
Right on… next time out be sure and fill the live well, the boat rides perfectly level with it full..
Unless they use different sealants on the FSH, CLEAR silicone was likely done by the previous owner, to something that sounds like it wasn't addressed properly. If I had to guess, look at your scupper valve (the biggest drain fitting on the transom - you can view it through the cleanout tray area). The two colors of sealant that you should run across is the black sealant (the "afterbirth" is the common one, but that's usually found within the first year-ish) and grey, used for most everything else and to glue the 2 pieces of your boat together. White would be the other typical color, but like I said, it's possible they switched sealants over the years - you still have something to track down.
Also
Clean out plugs;
I'm not sure I want to fill the live well. Sounds like it would be introducing a water intrusion problem that I would have to solve and based on what I'm reading from your post about it there are multiple points to address and I would need a video to get through that. As I read through it was difficult to understand where all those parts are and how to "fix" them.
