mmcneese01
- 222S
Can you get a small but sturdy pocketknife or pliers down the clean out port and try to pry it out?
Interesting approach on that my fear is if I get something up in there I don’t want to damage the little prop. They do seem pretty solid though should be able to handle itLong screwdriver or some thing to break the wood up is what I’d try first.
Start gentle and go from there. The impeller blades can handle a lot of abuse without damage…. like a 2ft long stick stuck in it.Interesting approach on that my fear is if I get something up in there I don’t want to damage the little prop. They do seem pretty solid though should be able to handle it
I will give that a try thank youStart gentle and go from there. The impeller blades can handle a lot of abuse without damage…. like a 2ft long stick stuck in it.
Exactly don’t want to mess up a day with fiends and family. I wish it would have cycled through so I could acces from the back. Thank you for your replyMight be a pump pull. I’ve never had to do it, which is pure luck since we boat mostly reservoirs, but I’ve seen videos of guys doing it in a half hour. I’ve seen claims of guys having to re-trailer, pull the pump, and red-launch which still saved the day for boating as well. I’ve looked around the area and have made sure I have the tools with me for doing it since we sometimes travel pretty far to boat and don’t want to screw up a vacation.
Good to know thank youI wouldn’t recommend removing the intake grates unless you feel confident that you can get them sealed properly upon reinstall. They need to be sealed up properly otherwise you’ll get cavitation. Try to make it your last resort.
