Engine Issue
Dshriber
I have my boat prepped for the start of the season - changed plugs, changed oil, tested and charged batteries, etc... Everything looks good. My gas is at 0% (on the trailer). My one engine will start (top key) but second engine (bottom key) wont turn over. Dumb question bit would one engine start when boat is low on gas or is it a different issue?
Thanks!
Get some gas in it and test this hypothesis 😂
On a serious note, make sure your throttle is in neutral and all safety switches are good.
It cranks but doesn't turn over. I'm filling the boat on the way to the ramp later in the week. Maybe the dealer didnt reconnect the spark plugs? thanks for the feedback!
Ah I figured you did all the work, definitely worth checking their work. Check all the ignition coil plug connections and are seated well on the spark plugs!
try moving the throttle back and forth before cranking the starter in case the throttle positioning sensor is acting up
The problem is you are out of gas. Why is your tank at 0%?
To me, cranking = turning over both are synonymous with the electric starter motor actuating.
I had something similar happen one day, I purposely ran the tank down to 1% maybe zero because I wanted to know if the boat would still run at that level, Aka I wanted to know how much useable fuel was in the tank. I had my trolling motor to take me in if it quit. Tied up at the dock with both engines idling, the starboard engine quit running, bottom key, so I put it on the trailer with the port engine. Once on the trailer the starboard started again. When I went to the gas station it took 52 gallons to fill it, so accounting for the fuel in the fill line line I’d say 50-51 gallons are useable out of the 52 gallons.
Thanks!
I had a similar issue begin randomly as well. Found out that the auto-cut off switches under the latch covering the cleanout ports were faulty. They were not depressing properly. To test my hypothesis, I placed a folded piece of cardboard on top of the switches to make sure they were pressed down all the way and closed the latch. Starboard engine (bottom key) started right up. Going to bypass switches next time I work on boat.
My hatch switches have been fine for the last 4 years but last weekend my port engine started before I launched but after I installed my clean out plugs it would not crank. Quickly electrical taped 2 quarters over that switch and it fired right up. Not sure why its needing depressed more to work now.
The hatch switches are adjustable but if it were the issue the engine will not crank over at all same as if the lanyard switch was the problem Any time I have has the engine crank but not fire it ended up being the throttle positioning switch and moving the throttle back and forth a bit usually worked
Why not adjust the switches instead of removing them? They’re a safety lock out device.
Maybe they were close on their adjustment and the pin finally wore down a bit or there is a bit of corrosion on the contacts 🤷🏼‍♂️
