Lithium House battery
Grkspeed17
252SD
Hey guys, we have a 2023 Yamaha 252SD that’s set up from factory as a two battery system. Currently I have two group 24 lead acid standard batteries from dealer. I want to upgrade the house battery or both depending on situation. They make some nice lithium group 24 sized 100ah batteries out there as an option for house but if I do it I want to do it right.
If I were to keep the regular start battery and replace the house battery with lithium, what would I need to do to have it be installed properly? Reason I ask is because some people on here just swap it right out and leave everything the same, some do some modifying maybe with the DVSR, and then some say the stators on the engines shouldn’t be charging a lithium battery.
If that last one is the case, should I be deleting the DVSR, and isolating the lithium battery so that it only gets charged by an onboard charger that can handle lithium? I’m just really confused as the what I should do as the best option. I want more time out on the water with the tunes on. I lean towards lithium because I like the idea of them holding a steady voltage closer to battery drain compared to LA batteries where I get 11 volts when the batteries are 50% discharged or so.
The last bit about the stators should not be charging lfp batteries is false. I’ve been running a Battle Born 100Ah lfp battery for two years now and it works great. The alternators on our boats are always at full output, the unwanted power is shunted to ground by the regulator / rectifier.
Having said that, you will have to modify the dvsr to make it work with the lfp battery, namely, the motors need to be on when the dvsr connects the lead acid start battery and the lfp house battery. Mine is set up to actuate manually with a rocker switch, others have tapped onto the fuel pump hot wire so that the dvsr is only active when the fuel pump that feeds that engine is running. Otherwise the resting voltage of the lfp battery will keep the dvsr closed and your lfp battery will try and charge your fla battery as the voltage of the fla battery is lower than the lfp battery.
Having said that, I think you need to determine whether or not you need a lfp battery for your house battery. Install a Victron Energy smart shunt on your current (see what I did there?) house battery and see how much power you actually use during an outing. Keeping in mind that a group 24 FLA battery is probably around 70 Ah, you should only be using 50% percent of that 70Ah to keep from damaging the battery, I see that you mention that but how do you know you are at 50%? And, if you do not already have an onboard charger and keep it plugged in then the fla battery will not be at full capacity.
If you still want to move ahead with the lfp house battery, click on “battery upgrade” in my signature. Its a big thread with a lot of great input by the members here and all the research I did. Lastly, if you are going to do this, only invest in a quality lfp battery, I highly recommend Battle Born, ReLion is also good, with Dakota Lithium coming in last.
I should have included more detail. I already added a switch early on to my DVSR because I have a Noco 5x2 onboard charger. The way I did it was I cut the black wire that connects to the house battery and added in a toggle switch so I can isolate the batteries when I charge them with the onboard smart charger.
Also, I just threw out numbers on 50% charge and voltage but most of the time after a full boat outing I would see voltage of around 12.3-12.4 by the end of the day but that included a long trip back home where the stators were adding in some charge. I plan on actually upgrading the audio but not by much. Maybe two 100ah batteries will be enough to also future proof any additional sound mods I may want to do in the future like adding tower speakers.
So it sounds like as long as I have the DVSR modded which I already have so I can charge whatever batteries I have separately with the onboard charger …. Everything else is just a drop in similar to if I replaced with a regular lead acid battery right?
My advice is to take the advice of @FSH 210 Sport. I had two Odyssey AGM batteries and replaced one of them with a 100Ah Battle Born LiFePO4 battery before last season and it worked out great. I highly recommend the smart shunt so you can monitor the actual battery voltage and charging rate in real time via Bluetooth using an app on your phone.
Yes, with your DVSR mod you can just drop in a LFP battery, but you have to remember to turn the DVSR off when you stop to float.
Check out @WiskyDan ’s posts in this thread; DVSR help... On how he tied his DVSR positive into a fuel pump hot for a simple way to operate the DVSR without a second thought. I know of at least one other person who set up their DVSR that way and I think I had told WiskyDan about it and he emulated that set up and wrote his post about it.
As far as the number of 100Ah LFP batteries you’ll want to have on board, LFP batteries have almost three times the amount of Ah / KWh of energy storage compared to a lead acid battery. I can’t stress enough the addition on the Victron Energy smart shunt, they are small and easy to install. No worries on tossing out the 50% number, a lot of people look at the voltage to determine battery state of charge, but to use voltage to determine SOC on lead acid batteries they need to be disconnected and at rest for 24 hours.
The Victron app for your smart device works with all Victron devices. I have two of these smart shunts installed on my boat, one for the trolling motor battery bank which is an isolated system and one for the house battery. The shunt also has a start battery tap that will measure voltage only on your start battery, I used this tap on the house battery shunt to see the voltage on my start battery. I’ve found on my boat the connext screen voltage reads low, usually .5 volts when in the lower voltage range, I’ve verified this with my fluke meter as well as the smart shunt, the shunt and my fluke (multimeter) read the same while the connext screen voltage reads up to .5 volts low.
My boat will read voltage on the connext screen (as well as the shunt) in the 14.2 to 14.4 range when cruising when the batteries are charged up, so yours were still low on your cruise back. Speaking of charging, LFP batteries charge five times faster than lead acid batteries so this is why LFP batteries are a great marriage to our alternators, as all of the output will be going into the LFP battery. Your boats alternators put out roughly 13-14 amps each when the rpm’s are above 3500 rpm, and approximately half of that at idle. This five time faster charge rate is where automotive style alternators (variable magnetic field or VMA) have issues with LFP batteries, but not with the alternators (permanent magnet alternators or PMA) on our boats.
You will also need to replace your on board 5x2 charger with at least a 10x2 as LFP batteries require 10A minimum. I had MinnKota 10 A chargers originally but have since switched to Victron IP67 chargers. The IP67 chargers are user configurable to any battery chemistry via the same Victron app and Battle Born customer service can walk you through the set up or I can help you set them up the way BB wants their batteries charged. The IP 67 chargers are capable of charging from 3A up to 25A. I have my trolling battery bank, 3-100Ah BB batteries, at 25A each, that reduced my trolling motor battery bank recharge time from 14 hours to 3.5-4 hours.
My suggestion for your set up would be to install one group 27/31 100Ah BB battery, the smart shunt, @WiskyDan ’s DVSR fuel pump hot mod and run that set up until such time you see via the smart shunt you are running short on capacity, if you reach the point where you need more capacity then add another 100Ah BB battery in parallel to double your storage capacity. These batteries are expensive so no need to install a second LFP house battery until you need it.
So far we’ve just talked about performance of these batteries another big factor is the weight savings, a BB 100Ah battery weighs half of a similar size lead acid battery, and LFP batteries weigh 1/5 of the weight of a lead acid battery bank of the same useable storage capacity. The other really big thing is these batteries they last 10 times as long, they come with a 10 year warranty, I expect to get 15 years out of my batteries and I use mine a lot more than the average boater as I have been averaging 35-40 boating days and 12-14 hours each outing a year. While I absolutely love my boat, there’s a good chance I may move to a larger boat with a bit more protection from the elements in the future, if and when that day comes, my MinnKota chargers and a new set of lead acid batteries will go into my boat for the sale and the LFP batteries and chargers will come out and go into the new or new to me boat.
Not sure if you read the thread I mentioned above; Conversion to LiFePo batteries Or not yet but I highly recommend that as well, I spent a lot of time researching this subject before I moved ahead with this project, @mrcleanr6 was exceptionally helpful with his suggested questions which allowed me to ask questions of the manufacturers, which is how I arrived at BB being the only choice. BB has excellent customer service and all their sales people are tech support as well and BB sells and fully supports Victron products, if they don’t happen to answer the phone leave a message and they will call you back pretty quickly. ReLion also has people you can talk to, but I could not use their heated batteries in series for my trolling motor bank. Dakota lithium has sales people you can talk to but if you have tech questions it’s a 24-48 hour response time and from what I’ve seen they balk at warranting their products, I helped a member here get his Dakota lithium battery replaced. Can you find less expensive LFP batteries? Yep, but you get what you pay for, and in the case of LFP batteries the BMS (battery management system) is vitally important to protecting the battery from over voltage charging, low voltage cutoff, high amperage in/out, low/high temp cutoff, allowable amperage in/out etc.. BB also uses a type of cell that is different from the other battery manufacturers that enable their batteries to continue working if one cell stops working where the other brands will stop working. This video is linked in the conversion to LiFePO batteries thread,
it’s a bit long but well worth the watch.
And lastly and also important to me is that other than a printed circuit board that is produced in China BB are designed and manufactured here in the United States.
You did not say if you were installing stereo equipment?
All this information has been awesome, so thank you! Another question for this “conversion”. What about needing a dual purpose cranking lithium battery as the house battery? Let’s say I have my standard lead acid crank battery as my starter, and just replace the house with a non cranking lithium battery and my starter doesn’t have enough charge for whatever reason to start the boat. If I turn on the yellow parallel switch will it matter if the lithium battery isn’t rated for crank amps? Or does it just give its juice to the start battery to do the job? I don’t know if that’s a stupid question or not but I’m a little new to battery chemistries and purposes for each. Redodo makes a group 31 140ah dual purpose cranking lithium battery for $400. That seems to check all my boxes in terms of potential needed capacity, having Bluetooth for monitoring, and being able to have power to crank the engines in an emergency.
Lastly, for the DVSR …. What about the red loop mod behind the relay itself? I thought that mod is set up so that it only activates the DVSR to operate as intended only when the engines are running automatically. Wouldn’t that solve the problem for me to not have to ever worry about the DVSR as a set it and forget it situation or it has to be tapped into the fuel pump hot?
Read through the battery upgrade thread linked in my signature, lots of great info there.
Most of the lfp batteries will start our engines without being a cranking battery, there a couple of people who have done that. And as used as a booster I’m sure it would work BUT but I still carry a jump pack for starting a low battery.
The dvsr mod is necessary whether or not you have a lead acid start battery with a lfp house or a lfp start and house battery. You can either set it up to operate manually off of a dash mounted rocket switch or tap onto a fuel pump hot to take it fully automatic.
I highly recommend buying the following lfp batteries; Battle Born battery as a first choice, ReLion as a second choice and Dakota lithium as a third choice. If you’re not willing to spend the dough on a known quality lfp battery don’t buy one, just buy a flooded lead acid battery. I’ve seen a few instances of people buying the cheapO lfp batteries and have had issues with them.
I chatted with Battle Born today and found out the following information.
-Dennis Phares the CEO of BB is on the ABYC board and helped craft the ABYC standards for LFP batteries.
-BB batteries with the intelligence meet ABYC standards as remote notifications is required among other things.
Following
Why not use a DC to DC charger to charge the house battery instead of the DVSR? No need for the isolation switches or concern for different battery types. One with MPPT and you could use solar to top of the batteries while at the sand bar too. What am I missing? Use this setup in my teardrop camper and works flawlessly.
You are correct, that’s another option which I may do down the road but figured it would be more economical to stick with using the DVSR already on the boat and just wire it to the fuel pump hot.
I actually just finished installing everything 3 days ago and everything seems to be working just fine. Very happy with it so far. The next move will eventually be to get a quality DC to DC charger, maybe Victron.
Nice and tidy - well done!!
What lithium batteries did you go with and what was your deciding factor/s?
Thank you! I went with Redodo batteries. I’m pretty sure they are made in the same factory as LiTime, PowerQueen, and more. Haven’t really heard of anyone have issues with the “cheaper” batteries. Figured I would give it a try. I also ordered and installed their battery monitor screen that I mounted by the switches just so we can always have a look at battery percentage in case Bluetooth on phone is having issues or anything like that.
Lastly, I installed a Victron 25A marine charger for the house batteries wired in parallel.
You must have one heck of an audio setup to need two lithium batteries - are they 100Ah each?
Yea two 100ah … it’s probably overkill but I did upgrade the amp from factory 600w to 8 channel Wetsounds 1200w … added 2 additional speakers. And eventually plan on adding a second amp to power a set of tower speakers.
The only time you really need a DC to DC charger is with automotive style alternators to protect them from being at too high of output for too long due to the low resistance of lfp batteries and their ability to take a very high rate of charge and most automotive style alternators regulator to limit alternator output when the alternator gets too hot.
Doing the storage / ignition hot mod to the BEP dvsr is how the device was intended to be configured as well as the way the DVSR comes set up. The ignition or fuel pump hot is the easiest way to set up a fire and forget method of operation. When set up correctly, which is in any mode the device has will isolate the start battery while on the water when bus voltage drops to 12.7, the exception is that with lfp batteries one has to do the fuel pump hot / ignition hot set up to keep the start battery and house battery isolated.
The other thing I will stress, again, is installing a Victron smart shunt before you start a battery upgrade project so you know how much power your system draws which enables you to make an educated and informed decision about how much battery storage you need. Doing anything else is just a guess and leads to spending money unnecessarily and having too many batteries. I’m going onto my third season with the smart shunt and have never had an issue with the two I have.
Thanks for the input. New to the boat scene. Just bought my first boat AR195 and seeing so many similarities with my teardrop build....but the nuances are real as you note. I've already got a shunt to watch the draw when I get it out on the water. Need to learn some thing before I start buying stuff as you suggest.
The big difference between automotive style alternators and the alternators in our boats is that the spinning magnetic field / flux density in automotive style alternators is variable and the flux density in our boats alternators is fixed.
Before we go any further, the two components of an alternator are; a Rotor, this is the spinning device that has the magnetic field, a stator is the fixed coil of wire attached to the engine.
The alternators in our boats are always at full output and the regulation of voltage / current is done with the external rectifier - regulator, the three phase AC voltage is rectified to DC voltage through the use of diodes (rectifier) and unwanted voltage and current are shunted to ground. These are called PMA or permanent magnet alternators as the spinning magnetic field (flux density) is fixed, the magnets are embedded in the flywheel or rotor and the field is spun around the coil of wire(s) which is called the stator.
In an automotive alternator the magnetic field (flux density) on the rotor is variable, VMA or variable magnetic alternators, and is controlled by the regulator, thus it’s power out is variable and the AC voltage is rectified to DC voltage through diodes. Both VMA and PMA’s produce electricity through induction which is passing a magnetic field over a coil of wire, this is also how transformers work as well.
The difference in power output between a given size / weight of PMA and VMA is exponential, a VMA can put out a lot more energy than a PMA but in doing so they get much hotter and the typical duty cycle of maximum power output of a VMA is about 10-20% whereas the PMA maximum output duty cycle is 100%. Some VMA’s have temperature moderated regulators so that when they get too hot the regulator pulls back on the output to keep it from burning up. In most cases a VMA alternator in a car is designed to quickly recharge a start battery after it starts the engine and the duty cycle quickly reduces from 100% down to say 10% or less or whatever is required to run the vehicle. Some VMA’s are built to handle 100% duty cycle, typically these are marine alternators or other installations where large charging loads are present.
Since LFP batteries have such a low resistance, the typical or non LFP battery compatible VMA regulator will command full output from the alternator until the LFP battery is 90% charged or it burns up. This is one problem legacy VMA regulator controlled alternators have with LFP batteries. The other main issue is how the BMS or battery management system in LFP batteries protect the LFP battery from overcharging, the non start type of LFP batteries BMS system can or will just cut off the battery, this results in the VMA having nowhere to send its power before the field collapses in the alternator and the diodes in the rectifier will be destroyed and the alternator is toast. This is the reason all of the outboard engine manufacturers said no LFP batterIes can be used with our engines, if you do use them your warranty is voided. A lot of the outboards have PMA in them by the way. Recently however Mercury has approved ReLion start batteries to be used with quite a few of their engines. I know Yamaha Outboards still says no to LFP start batteries, Yamaha is typically very slow to change technologies across the board this yields Yamaha as one of the most reliable engines on the market, there’s a reason that the vast majority of commercial boats all use Yamaha engines. I’m not sure about Honda and Suzuki. And this is where the DC to DC charger comes in, the DC to DC charger has a limited output, some like the Victron is either adjustable through the user interface or their output is set. Typically the output is 25-35 amps which limits the VMA to a sustainable duty cycle. The DC to DC charger also acts like a DVSR / VSR / Charge Relay to keep the start battery isolated from house or accessory loads. All the DC to DC chargers work on the principal of only charging once the voltage comes up to 13.3-13.4 volts which insures the start battery has a good charge on it, and then the DC to DC charger turns off once the voltage drops to 12.7-12.8 volts. And, if you set your system up with a lead acid start battery there is always some place for a VMA or PMA to send its power to.
An advantage PMA’s have is that once the motor is running they will produce power on their own, they’re not reliant on voltage from the battery for the magnetic field, unlike VMA’s which require a certain level of voltage from the battery to maintain the rotor field.
In summary the PMA’s in our boats are a good marriage for supporting a LFP house battery. Based on what I’ve learned I have stayed with a lead acid start battery, an AGM type, as they are superior for starting applications.
That’s a lot of blah blah blah about alternators but you should have a good idea of what the differences are and how they work.
P.S. Based on what I’ve learned and observed there are only two LFP batteries that I would recommend ReLion and Battle Born. I’ve seen enough issues here and elsewhere with inexpensive LFP batteries to make that recommendation. Another big advantage of LFP batteries is their service life, 10 - 15 times longer than lead acid. I know that if I ever sell my boat the LFP batteries and associated equipment will come out and lead acid batteries will go back in for the sale.
