Looking for someone with audio experience and a 222/252/255 with Factory Tower Speakers
Adrian @ JB Solutions
Tampa Bay, FL
252SE
Working with a buddy to try to activate the tower speaker zone. Looking for someone with the factory tower speakers that can identify the four speaker wires for the tower signal and take a picture of how they are pinned on the 12" connext.
What model are you working on. The connext screen does not directly power the speakers.
I have a 252, the Connext provides low level outputs. The tower wires are blank on mine, we are thinking if we can determine which pins go to the tower zone and mimic a load that we may be able to activate the tower zone.
Adria take a 12v battery and touch the speaker wire 1 by 1 they will make a noise so you can tell which wires go to which speakers
I don't have wiring for the towers so I can't do this. Also this is a bit risky on a can network like our boats - checking resistance is a much safer method.
If your just popping speaker wires, yeah that works well. I actually have several tools specifically for this. In a pinch, a 12v drill battery also works.
Yes that's what use a drill battery, easy way to find out which cable are connected to which speaker
ok so I have a 255xd what exactly do you need pictures of 4ch amp connector or back side of the connext screen?
Back side of connext. There will be two plugs, to the port side is a blue plug. That is the one with audio output.
You can go online and for 14.99 get the full wiring diagram with pin outs on amp and connext side and the whole boat if you want. I have them saved somewhere. I'll see if I can find them.20230321_212018.jpg
Thanks, I will bump this against the 252. Do you know where I can purchase wiring diagram for the boat?
Maybe @Seno could help. We live around the corner from one another and has offered to help do some electrical work on my boat when I was thinking about doing a GPS.
