Tuning on the cones? Washer setup?Any updates on this?
No shims port, 5mm starboard side.
So are you buying a set of twin screws? Buying a set of standard impellers?Welp.... I apparently still have quite a bit of cavitation I need to get rid of. The last two outings with 5-6 people in the boat and 2 adult size children on a double tube, it is really struggling to hook up. So much so that after a few seconds of cavitation, the boat drops rpms down to 5k and won't go above that unless you go all the way back to neutral and try again. Ended up having to move people around to distribute weight just right to get on plane. Kind of tells me that for a "surf" boat, Yamaha propped this thing all wrong. Maybe instead of being capable of 55mph plus speeds, it should be able to get a boat load of people up on plane. I can't imagine trying to surf with full ballasts and more than 2 people on board.
So I reached out to David at Leading Edge. Super friendly and eager to help whether I was ready to purchase from him or not. I highly recommend contacting him if you ever have any impeller questions at all. Ran thru my current list of mods with him and told him about the results @jacoviii has reported with the 12/18 vs the 12/20 options, with and without his L13 cones installed. He said that he could pitch two impellers for me that would designed to specifically work with the L13 cones I have already. Sounded pretty confident that he could get rid of my cavitation issues and add at least 2mph to the top end. So, we'll see, they should be here next week.
Twin screw.So are you buying a set of twin screws? Buying a set of standard impellers?
I’ve spoken to him as well.. he’s very impressed with the twin screw impellers.
Which pitch did you get?Got them installed finally. Only had about 20 minutes to spend in the water this morning, gotta go help my daughter move this afternoon.
Initial results seem to be spot on with @jacoviii has posted. Not surprised since we’re running the same boat at pretty much the same elevation with almost the same mods.
Cavitation is still slightly present at hard acceleration from idle, but I would wager to say reduced by 85-90%. If cruising on plane, hard acceleration is amazing up to 47-48 then slowly creeps up to 55. Hook up while cornering is a 200% improvement. Feels like a different boat in the turns. Top speed was 55 with half tank of fuel and just me onboard, which is only down 1mph from 56. 7700rpms port and strbd, which is down from 7800-7900 I was getting before. Gonna take the L13s off and go back to stock cones and give it another try again tomorrow. Hoping to get rpms back up closer to 7900 and get my 1mph back.
Easiest way to explain it is two differently pitched impellers stacked on top of each other.What are these “twin screw” impellers?
The box said 12/18, but they were supposed to be custom pitched to get rid of most of my cavitation while not losing top end. So I think they did job. Still waiting on David to get man to me on specifics.Which pitch did you get?
What was the temp ?
At 78° and X amount of humidity that’s going to raise your DA ( density altitude a bit) that would raise the DA up to roughly 2000’. While SC engines are as impacted as NA engines there will still be a noticeable drop in power.The box said 12/18, but they were supposed to be custom pitched to get rid of most of my cavitation while not losing top end. So I think they did job. Still waiting on David to get man to me on specifics.
Air temp was about 78 this morning while I was out. Water temp was 89 off I remember correctly.
What was the air and water temp ?Got a chance to get back out for a few hours this week. Reinstalled the L13 comes, but added in a 2mm washer on each side. Maxed out at 7700 rpms just like without washers. Top speed remained at 55mph. Had some slight cavitation if I slammed the throttle to WOT from idle. If I rolled the throttle on quickly and smoothly from idle, I had almost no cavitation at all.
