The ultimate leak finding thread <post if you find a new source!>
Yes, I can see the inside of the drain plug from the access hatch, but when I looked, it was already under the water in the bilge so I couldn't tell if water was coming in there.
My issue is that water is coming in over the plugs on 242 limited S. Things that I have tried and have not worked for me:
1. Rebuilt plugs
2. Used wax on plug seals
3. Used pool silicone on plug seals
4. Cleaned / buffed inside aluminum in housing
5. Replaced entire plugs with new Yamaha plugs
6. Used wax with new plugs
Nothing has worked. Any suggestions??
It's most likely not blow by from the plugs, but water coming in through the access hatch drain. When you stop, water can be forced up through the drain and then run into the plug cavities. A way to test would be to plug the drain next to the cleanout plugs and see if you still have water on them.
It’s not that. I have a riser on the cleanout tray and a valve on the hatch drain.
search and find the thread on adding o-rings....that should stop it the water accumulating on top of the cleanout plugs.
Turns out my leak was the drain plug. There was a lot of junk in the bilge next to the plug and some junk that was crudding up the threads. I cleaned all that out, cleaned the threads, and sprayed some silicone lube on the plug o ring and that stopped the leaking.
Some members have put a gopro camera under the hatch with a light to see where water is coming from (or just over rode the lockouts and left the hatch open and watched.
Are you convinced water is blowing by your plugs?
I found a new source of leaking in my boat... the infamous anchor locker drain. But not the drain hole itself as I had plugged it completely with silicone years ago. No, this time it seemed to be the small area between the fiberglass and drain hole. I ran a thin bead of silicone around it and had less water in my boat over the weekend than previous times.
I still need to tackle my rear rub rail. I noticed over this past weekend that, while sitting on the rear transom with a couple of people at the sandbar, the rub rail dips below the water line. That's my latest suspect for water in the boat.
I’m not 100% certain, but pretty sure. I ran it the other day on the hose for about 10 minutes and water was full above the plugs and water in the bilge. I’m going to put on the O rings when they come and run it with the hatch open to see if it’s something else. Could be the intermediate bearings or even a leak from the shutoff valves I installed a few years back. I’m not ruling out those yet but the plugs seem to be the likely culprit. I’ve sealed the tray, put on the JBP riser and put in a blowback valve on the drain. I still think water leaks through under pressure in the tube itself when it gets past the plugs. I’ve put a second bilge pump in the bilge so I’m not super concerned, BUT… I just don’t like water in the bilge.
Also, I know there is no water getting in from any other source. I’ve done the complete rundown on the leak thread.
Are you saying that you still have the OEM white plastic fitting as your drain fitting for the anchor locker?
To reiterate and summarize the steps to having a dry bilge and storage areas on our boats.
Pick this thread up at post #90 with @TeeNGee, arguably the single best way to eliminate the largest source of water getting into our boats. He deserves a gold star ⭐️ and evenings in the corner of excellence for doing the homework on finding the correct O ring.
This takes care of the sneaky water getting in
Sealing the cup holders against the hull is a necessity to keep rain water / wash water out of the bilge and storage compartments. As well, make sure those with OEM drains have their hoses connected firmly. Cup holders without factory drains can have drain lines installed to put water overboard, on to the deck or just plug them and remove any water collected there with a microfiber towel.
On the FSH series sealing the rod holders against the cap rails and installing universal rod holder drains on the bottoms of those that didn’t come with them and plumbing them either overboard or onto the deck will keep the storage compartments dry and keep water out of the bilge. Same is true for the cup holders that drain directly into the bilge, especially helpful on the FSH series where the raw water wash down is used throughout a day of fishing to clean up the deck. Some FSH series need to have sealant where the center console meets the deck touched up.
Removing and sealing up the rub rail at the stern, especially for those that wake board with a lot of ballast that submerges the rub rail will keep water from getting in there.
Checking and or resealing the deck drain fitting(s) as well as the drain line itself to the thru hull scupper. Better yet, replace the plastic OEM thru hull scuppers for the deck drain(s) and or live well drain(s) with quality stainless steel units and seal them with copious amounts of 3M 5200 will not only ensure these are not leaking but also eliminates a ticking time bomb of failure that could cause your boat to sink when these fittings become brittle with age, crack and start leaking, or as a few members here have experienced a total failure occurs and the bilge will flood.
Add a mechanical hatch riser from Jet Boat Pilot.
Make sure the bilge is clean and free of debris especially in the area where the hull drains are, the hull drain hole is clean and the O ring on the plug is in good shape and lubricated with silicone or pool lube.
There are a few edge cases where leaks occur at the impeller shaft pas thru in the aft bilge.
Having a dry bilge not only preserves your boat and keeps you from relying on your bilge pump, but also helps to remove an area of transport of aquatic invasive species.
Good Stuff here !
