jcb1977
- Elkhart Lake, WI
- SX
The easiest way is to just run a wire from ACR post #1 to Battery Switch Load post #1 (accessories) and another from ACR post #2 to Load Post #2 (Outboard).....no power draw when switch is off and you can independently charge each battery.
I would put the fuses between battery and battery switch. If you used the 65 amp mini , I would put a 60amp fuse on each positive to protect that switch.
Alternatively, you can leave it the way you have it and just add a switch to the ACR ground but will have to make sure to turn that switch off everytime after using it so it doesn't draw in storage and/or when you charge the batteries. But I would still get 60-amp fuses in to protect that switch.
If that 60-amp fuse trips a few times, it's a sign you should upgrade to the 120-amp version.
