XD Power Steering Adjustment Issues
F.M.
Decatur, AL
255XD
Alright, taking my boat to the dealer next month to leave with them to try to figure out the power steering. It turns much harder to the right than it does to the left. The turning radius to the right is half what it is to the left. Found posts about wires on the board being secured too tightly or too loosely causing problems, but the wires seem to be secured correctly. What sensors should I ask the dealer to check to possibly shorten my wait to get it back?
So the 255xd with the drive tech is and electric steering wheel sensor, an electric hydraulic pump and a hydraulic cylinder.
You should feel little to no resistance in the steering wheel. technically there is electro magnets to simulate steering feedback but on my 2022 it has little to no feedback.
The turning radius to the right is half what it is to the left. Is either an issue from the surfpoint " nozzles toed in" to center the jet blast,
Or you need to have the Yamaha tech run a steering re-calibration.
A easy way to check overall steering is to make a few marks on the ram slides.
Step one with the boat off, turn the hydraulic pump bypass knob fully open.
Then push the ram/ cylinder fully extended and mark this position on the white slides.
Now fully retract the ram/cylinder and mark this position on the white slides.
Next I measured this overall length and found center.
Now put ram/cylinder in the center position. (This is not critical the system will self cent during next restart.) After centered close the / tighten the bypass knob.
Now with the boat running turn fully left then fully right While checking to see if you are getting full movement from the system.
My boat spent 2 months at the dealer with just 4hrs on it. They ended up putting 25hrs on it trying to fix steering issues, I'm ok friends with the service manager so I was kept in the loop. I also helped during some of the testing.
My ram/cylinder magnet position sensor was loose inside the cylinder causing faults.
Should have noted also that when cruising on plane top center of my steering wheel is at 10 o’clock instead of 12.
FWIW,
I thought @Neutron mentioned in another post about there being a self calibration the BCU unit does to center the steering rams using the magnets on the shaft?
I remember reading that somewhere also. But with what I’m experiencing, I’m thinking it’s probably more along the lines of what @jacoviii described above, a loose magnet/position sensor on the ram. When we get back from home I’m going to mark the rams and check the movement as suggested. I don’t think my wife wants to spend time on vacation working on the boat when she doesn’t even know/understand anything is happening.
FWIW,
That was for the reverse gate. I am not familiar with the electric steering yet
There is but my service manual subscription ran out. I think you need Yamaha software to run it though. I have read how to do it on seastar/Dometic website. They are the manufacturers of the system. But I belive that yamaha is plugged into the nmea port so not sure what all is going on there.
Here is a pic of what is left of my marks.
Finally got a chance to look at my steering and mark as suggested by @jacoviii. Looks like when at full turn to left the steering rams are pretty far from full left.
Manual override movement in black. Steering wheel movement in red. Right turn marks line up just fine.
We’re gonna have plenty on rain and cooler temps for the next week or two so I decided to drop it off at the dealer on Tuesday. Showed them the marks on the steering rams while talking thru my issue. They agreed that Yamaha should fix it and got to work on it.
Amy updates?
Amy updates?
Not yet. Talked to the dealer on Thursday and their jet boat tech had a family emergency and hadn’t looked at it yet. He was expected to be back today to get it in to start on. They normally take good care of me with fast turn around times, so I’m not going to complain.
Dealer isn’t as competent as I thought. They “removed excess silicone” from somewhere and said it was fixed. Upon inspection I left it with them because it wasn’t fixed.
Hello. Do you mind sharing what came of this? I have 2022 212x that is doing the exact same thing, turns tighter to the right and the steering wheel is off center to the left (10:00ish). Thank you.
At the end of the season last year, the dealer claimed they “recalibrated” the power steering, but I wasn’t able to go out again in it to test. Haven’t had out back out this year yet either. Hope to get it in the water next week so I can get it back to the dealer before my warranty expires if it isn’t fixed.
Can you please update this thread? I too have an issue where the boat has much tighter turning radius to the left (more responsive, tighter turns left) than to the right. Turning right is what I describe as sluggish, both at speed and in Drive X. Very different turning response left vs right.
2025 255XD
@F.M.
2025 255XD
@F.M.
Still have the same issue. I have checked and adjusted the nozzles at the transom, but haven’t checked anything adjustment wise at the power steering pumps yet. I’ve been working too much to even get out in it more than a few hours every 2-3 weeks.
