steve0617
- Littleton CO
- AR195
'17 AR195 here ... has done it since day 1 ... doesn't matter if it is on the trailer or in the water. It does not like a cold start. It will turn over about 5 or 6 times before it fires up. It will have a low and rough idle to it for about 2-3 seconds, then dies. Most of the time it will fire right up and idle fine on the second start (once in a great while it will die). But after that it's all good. Once the engine is going, no more issues the rest of the day. Annual tune-ups, change of plugs, etc. ... nothing has made it any better. After 5 years of ownership, I've just learned to live with it.
My 19 AR195 is the same. It turns over and fires fine but then dies. Usually I’ll pop it out of idle and gun it a bit to make sure it stays running. Problem of course with no neutral, is that causes me to move around the dock.
So now when I pull it out of the garage into the street to put the tower back up, I’ll go through the routine until I get it to run on its own. Then we head to the reservoir. That way, I know 100% I’m not gonna be “that guy” blocking the ramp cause my damn boat won’t start.
