No electronics workin but still runs
Van T
Chesapeake va
Cigarette plug arked now no power to any thing on the boat
not sure about your year boat but check near your battery to see if you have an inline fuse, if not there might also be one near the ECU,
Does the engine start? are you on the water now?
I was checked the fuses all good 2016 FSH trying to fix by tomorrow please help switched out all relays nothing
Tell us which fuses you checked so we know if you missed one
Yes, I would check the "blade fuse" in bat compartment.
Did you find your blown fuse? Where was it?
It's a 20 rt were the battery switchs are rt above them hard to see it just rt under the deck looks like a end of a wire harness capped off.easy to miss everyone should bring some extra 20 fuses when it goes out no power to any electronics . But motor will still run no Bilge, gauges,codes, alarms.
